American forum of research of Kolob Order
Forum américain de discussion du Kolob Order
  FAQ · Search · Memberlist · Usergroups · Profile · Log in to check your private messages
 Register · Log in
1986 Japanese Airline 1628 Encounters UFO
Post new topic   Reply to topic    American forum of research of Kolob Order Forum Index -> TRAVEL THROUGH THE UNITED STATES -> ALASKA -> UFO ACTIVITY
Message
ADAMA
PostPosted: Wed 16 Dec - 00:18 (2009)    Post subject: 1986 Japanese Airline 1628 Encounters UFO Reply with quote
November 17, 1986 Over Northeastern Alaska
It was just a routine flight. Well, not exactly routine... It was a special Japan Air Lines 747 cargo flight to carry a load of French wine from Paris to Tokyo. The flight plan would carry flight 1628 from Paris to Reykjavik, Iceland, across the North Atlantic and Greenland, then across Canada to Anchorage, Alaska, and finally across the Pacific to Tokyo.
The crew consisted of veteran Captain Kenju Terauchi, co-pilot Takanori Tamefuji, and flight engineer Yoshio Tsukuba.
On November 16, 1986, laden with wine, JAL1628 took off from Paris and flew the first leg of the trip, to Reykjavik. The next day, they continued, flying over Greenland and then across northern Canada without event.
Just after they crossed into Alaska, at 5:09 PM local time, Anchorage Air Traffic Control contacted them on the radio to report initial radar contact. The Anchorage flight controller asked them to turn 15 degrees to the left and head for a point known as Talkeetna on a heading of 215 degrees. They were at 35,000 feet and traveling at a ground speed of about 600 mph.
At about 5:11 PM local time, Captain Terauchi noticed the lights of some sort of aircraft about 2000 feet below and 30 degrees to the left front of them. He decided that the aircraft was probably an American jet fighter from nearby Eielson or Elmendorf Air Force Bases patrolling Alaskan airspace, so he ignored them at first. However, after a few minutes, he noticed that the lights were keeping pace with his own aircraft, which would be an unusual thing for patrolling jets to do.
It was about seven or so minutes since we began paying attention to the lights (when), most unexpectedly, two spaceships stopped in front of our face, shooting off lights. The inside cockpit shined brightly and I felt warm in the face.
Terauchi said that it was his impression that the two objects he had seen below them minutes before had suddenly jumped in from of him. The craft, one above the other, kept pace with the 747 for several minutes, moving in unison with an odd rocking motion. After about seven minutes, they changed to a side-by-side arrangement.
Terauchi said that the "amber and whitish" lights were like flames coming out of multiple rocket exhaust ports arranged in two rectangular rows on the craft. He felt that they fired in a particular sequence to stabilize the craft, much like the small maneuvering thrusters on the Space Shuttle.
He also reported seeing sparks like a fire when using gasoline or carbon fuel.
Co-pilot Tamefuji described the lights as "Christmas assorted" lights with a "salmon" color. He said: I remember red or orange, and white landing light, just like a landing light. And weak green, ah, blinking. He also described the lights as pulsating slowly. They became stronger, became weaker., became stronger, became weaker, different from strobe lights.
The lights were "swinging" in unison as if there were "very good formation flight...close" of two aircraft side by side.
He described the appearance of the lights as similar to seeing "night flight head-on traffic", where it is only possible to see the lights on an approaching aircraft and "we can not see the total shape." He said, I'm sure I saw something. It was clear enough to make me believe that there was an oncoming aircraft.
Flight engineer Tsukuba, who sat behind the copilot, did not have as good a view of the lights. He first saw them "through the L1 window at the 11 o'clock position" and he saw "clusters of lights undulating". These clusters were "made of two parts...shaped like windows of an airplane". He emphasized that "the lights in front of us were different from town lights." He described the colors as white or amber.
Tamefuji decided to call Anchorage Air Traffic Control, and for the next thirty minutes the 747 and AARTCC were in constant contact regarding the UFO.
During this time, Captain Terauchi asked Tskububa to hand him a camera so that he could attempt to take a photograph of the lights. However, Terauchi was unfamiliar with the camera and could not get it to operate. Tsukuba also could not get his camera to operate due to problems with the auto-focus and finally gave up trying to take a photo.
At this point they began experiencing some radio interference and were asked by Anchorage to change frequencies. Terauchi later said that Anchorage kept asking him about clouds in the immediate area: They asked us several times if there were clouds near our altitude. We saw thin and spotty clouds near the mountain below us, no clouds in mid-to-upper air, and the air current was steady.
Soon after the exchanges about clouds, the objects flew off to the left. Terauchi said later: There was a pale white flat light in the direction where the ships flew away, moving in a line along with us, in the same direction and same speed and at the same altitude as we were.
Terauchi decided to see whether they could see anything on the 747's own radar:
"I thought it would be impossible to find anything on an aircraft radar if a large ground radar did not show anything, but I judged the distance of the object visually and it was not very far. I set the digital weather radar distance to 20 (nautical) miles, radar angle to horizon (i.e., no depression angle). There it was on the screen. A large green and round object had appeared at 7 or 8 miles (13 km to 15 km) away, where the direction of the object was.
We reported to Anchorage center that our radar caught the object within 7 or 8 miles in the 10 o'clock position. We asked them if they could catch it on ground radar but it did not seem they could catch it at all "
At 5:25:45, after spending two minutes looking, the military radar at Elmendorf Regional Operational Control Center also picked up something. The ROCC radar controller reported back to the AARTCC that he was getting some "surge primary return." By this he meant an occasional radar echo unaccompanied by a transponder signal.
As the 747 neared Fairbanks:
"The lights (of the city) were extremely bright to eyes that were used to the dark. (The cockpit lights had been turned off to eliminate window reflections of internal lights.) We were just above the bright city lights and we checked the pale white light behind us. Alas! There was a silhouette of a gigantic spaceship. We must run away quickly! "Anchorage Center.
The JAL1628 is requesting a change of course to right 45 degrees." It felt like a long time before we received permission.
Just after the plane turned to the right, the AARTCC controller called the Fairbanks Approach Radar controller to find out whether or not the short-range radar had a target near the JAL. The approach radar reported no target other than JAL1628. "
The plane came out of the turn and flew toward Talkeetna at an altitude of 31,000 ft, with the object still following.
At about 5:40 a United Airlines passenger jet took off from Anchorage and headed north to Fairbanks. The AARTCC controller decided to ask the UA pilot to try to see the object that was following the JAL flight.
The UA pilot said he would look when he got closer. The controller asked the JAL flight to stay at 31,000 ft and the UA flight to stay at 29,000 ft. He then directed the UA flight to turn some more so that the planes would pass within five miles of one another.
As the United Airlines jet got closer, the UFO apparently dropped behind, allowing the JAL plane to get far ahead. The United pilot asked the AARTCC to have the JAL pilot flash the headlights on the JAL aircraft so he could locate the plane. At 5:49:45 the JAL pilot did that. At this point the planes were about 25 miles apart.
When the planes were about 12 miles apart, the UA plane reported seeing the JAL plane and nothing else. But by this time the UFO had apparently disappeared, not being seen by JAL1628, either.
At about 5:51, the AARTCC requested that a military TOTEM flight in the area also fly toward the JAL plane for a look. During the next several minutes TOTEM viewed the JAL plane but couldn't see any other traffic. JAL1628 proceeded to Anchorage and landed at 6:20 PM.
The FAA conducted an investigation of the incident, and did not issue its final report until March 5. CSICOP's (Committee for the Scientific Investigation of Claims of the Paranormal)Phil Klass issued a premature statement on January 22 claiming that the UFOs were the planets Jupiter and Mars - an impossible solution because the UFO was seen in a part of the sky opposite the position of these planets and because the UFOs moved from positions one above the other to side by side.
CSICOP later issued a second explanation that the UFO was light reflecting off of clouds of ice crystals - also unlikely because the sky was clear at the reported altitude of the UFO. The FAA attributed the radar images received by ground radar to a "split radar return from the JAL Boeing 747."
Loy Lawhon
December 8, 2006-One December evening in 1986, reports Shukan Shincho (Dec 7), two Kyodo News journalists presented themselves by appointment at the London hotel room of JAL pilot by the name of Terauchi. He had a story for them – but should he be telling it? Should they be listening? Are UFOs serious?
Journalism is a skeptical trade, and as for pilots, even if they do spot strange lights, objects and movements in the sky for which they can conceive no other explanation, they are expected to keep their suspicions to themselves. Their livelihood depends on passengers' confidence. Talk of UFOs does not encourage it.
So Terauchi, in granting the interview, was stepping out on a limb. He later paid the price.
On Nov 17, 1986, he told the Kyodo journalists, he was chief pilot on JAL flight 1628, Narita-bound from Paris. The first stop was Keflavik, Iceland; the second, Anchorage, Alaska. At 5:10 p.m. local time the plane, a Boeing-747 jumbo, was flying 10,600 meters over Alaska. It was dusk, not quite dark.
"Suddenly," Terauchi said, "600 meters below, I saw what looked like two belts of light. I checked with the Anchorage control tower. They said nothing was showing on their radar."
But something was emitting those lights, and whatever it was seemed interested in the jumbo, for it adjusted its speed to match to match the plane's – "like they were toying with us," said Terauchi.
That went on for seven minutes or so. "Then there was a kind of reverse thrust, and the lights became dazzlingly bright. Our cockpit lit up. The thing was flying as if there was no such thing as gravity. It sped up, then stopped, then flew at our speed, in our direction, so that to us it looked like it was standing still. The next instant it changed course. There's no way a jumbo could fly like that. If we tried, it'd break apart in mid-air. In other words, the flying object had overcome gravity."
Five minutes later, the object vanished in the gathering darkness, but soon another, much larger object, "several tens of times larger than a jumbo jet," which itself is some 70 meters long, appeared, bathed in blue light. Again the control tower radar registered nothing. Terauchi noticed unusual silhouettes over Fairbanks, Alaska. The object vanished. The jumbo landed at 6:24 p.m. and the passengers disembarked, not so much as suspecting what a harrowing experience their pilot had been through.
What to make of this? It's tempting to say Terauchi's imagination got the better of him; but he's an ex-fighter pilot with more than 10,000 flying hours under his belt. He would know, if anyone would, how to keep his imagination in check. Another theory Shukan Shincho hears is that the lights the pilot saw were from Jupiter and Mars, which in fact would have been visible on the jumbo's flight path on the night in question. It's possible, but again – would a man with Terauchi's experience and training be so easily fooled?
There are other possibilities, among them a secret U.S. military operation or development, about which nothing is known precisely because it is secret. Or maybe it really was what Terauchi says it was – a UFO. In any case, Terauchi was shortly afterwards grounded by JAL for talking to the press. He was given a desk job, and only reinstated as a pilot years afterwards. Now 67 and retired, he lives quietly with his wife in a small town in north Kanto, and talks about the adventure as little as possible.
"I spoke to a doctor – he said it was an illusion," he tells Shukan Shincho. "You saw something you weren't meant to see," his wife says consolingly. That, if nothing else, seems certain.
Reference : http://www.ufocasebook.com/jal1628surfaces.html
PostPosted: Wed 16 Dec - 00:18 (2009)    Post subject: Publicité
ADAMA
PostPosted: Wed 16 Dec - 00:20 (2009)    Post subject: 1986 Japanese Airline 1628 Encounters UFO Reply with quote
Monday, November 17, 2008
VIDEO: UFOs - FLIGHT 1628 JAPAN AIRLINES This is an old UFO account of Japanese Air Line, flight 1628 as it encountered three UFOs. The video below is an excerpt from The History Channel. The article, written by Dennis Stacy is one of the oldest accounts on the Internet in regards to this UFO encounter.
Captain Terauchi of JAL flight 1628 was equally convinced that he had encountered an extraterrestrial craft in the skies above Alaska.
JAL flight 1628 Captain Kenju Terauchi
People have been seeing unidentified flying objects in the skies for years. But when the eyewitness is up there with the UFO, is the sighting more difficult to explain?
By Dennis Stacy
for Air & Space Magazine
December 1987/January 1988
In the late afternoon of November 17, 1986, Japan Air Lines flight 1628, a Boeing 747 with a crew of three, was nearing the end of a trip from Iceland to Anchorage, Alaska. The jet, carrying a cargo of French wine, was flying at 35,000 feet through darkening skies, a red glow from the setting sun lighting one horizon and a full moon rising above the
A little after six p.m., pilot Kenju Terauchi noticed white and yellow lights ahead, below, and to the left of his airplane. He could see no details in the darkness and assumed the lights were those of military aircraft. But they continued to pace the 747, prompting first officer Takanori Tamefuji to radio Anchorage air traffic control and ask if there were other aircraft nearby. Both Anchorage and a nearby military radar station announced that they were picking up weak signals from the 747's vicinity. Terauchi switched on the digital color cockpit weather radar, which is designed to detect weather systems, not other aircraft. His radar screen displayed a green target, a color usually associated with light rain, not the red he would have expected from a reflective solid object.
Source :  aliencasebook.blogspot.com/2008/11/video-ufos...
PostPosted: Today at 13:55 (2018)    Post subject: 1986 Japanese Airline 1628 Encounters UFO
Post new topic   Reply to topic    American forum of research of Kolob Order Forum Index -> TRAVEL THROUGH THE UNITED STATES -> ALASKA -> UFO ACTIVITY All times are GMT + 1 Hour
Index | Administration Panel | How to create a forum | Free support forum | Free forums directory | Report a violation | Conditions générales d'utilisation
Template Stargate Atlantis by dav.bo
